Western Members CA, AZ, NV, UT, CO, NM, HI
2000 Impala Motor Mount Problem
Old Aug 1, 2008 | 07:14 PM
93Z28rare's Avatar
Default 2000 Impala Motor Mount Problem
My friend has a 2000 Impala with the 3.8 L motor. The front passenger side mount busted, was replaced with a new mount, and it busted again the next day. The mount is hydraulic fluid filled. What could be causing the mount to break so quickly. Any help is appreciated. Thanks.
Carlos
Old Aug 1, 2008 | 08:24 PM
jsteele90's Avatar
maybe another mount is broken and is causing more stress on that mount.
Old Aug 2, 2008 | 01:38 PM
m6ttop's Avatar
or the bolt went in crooked
Old Aug 2, 2008 | 03:31 PM
93Z28rare's Avatar
Got it guys. Well, we'll check out all mounts then. Thanks.
Carlos
Old Aug 2, 2008 | 05:11 PM
HEYPAL01impala's Avatar
those break alot under high stress tell your buddy to stop stalling up the car lol...j/k but anyways check both passanger dog bone and the engine mount that is next to the crank pulley. Check all the rubber mounts. and make sure the dog bones are on correctly. Anymore problems send me a pm.
Old Aug 2, 2008 | 10:12 PM
93Z28rare's Avatar
The mount that keeps going out is the one next to the crank pulley. The dog bones are the metal pieces attached to the radiator support and the top of the block right?? Would you happen to know the location of all the mounts as well? Thanks.
Carlos
Old Aug 3, 2008 | 01:15 AM
yeah 4 of them 2 dog bones rad support ones, then the one by the crank pulley then the trans other side of the car driver side...on the trans lol. Those are them.
Old Aug 3, 2008 | 04:54 PM
93Z28rare's Avatar
Cool man. Thanks. We'll be checking the trans one today and replacing the one by the crank pulley again. If it doesn't work, I don't know what it could be.
Carlos
Old Aug 3, 2008 | 05:51 PM
make sure one of the dog bone mounts...the actual mount to the block isn't cracked THEY love to break. Ive broken them a few times already lol. Next thing is try getting a better mount zzperformance.com has a good one. Look under grandprix same car just different body panels.
