getting cold feet...
m6 or a4?
where would you like your powerband?
final drive ratio? (gears)
full weight?
any future plans of forced induction/nitrous?
fill me in on that info and i can spec you out a cam that will fulfill your needs...
I made 450/440 w/ that exact setup on a conservative tune. The car weighed 3700 w/me in it and ran 7.5x in the 1/8th w/ a 1.65 60.
Doug
Saying that, I think with the weapon and ability you have available, you should lay down the pea shooter, and go with the upgrade to the full auto.
I think with your proposed set-up, going with the 10 round clip would be a miscarriage of justice and would make my banana clip shrink to a jalapeno clip.
You have the parts for an awesome setup! I would use what you have, get a decent cam (low 230s or high 220s or even the mamo cam) and put it together. Get it tuned right by CMS and it will be very drivable. You dont need to worry about drivability until you step up to a big cam like an MS4 and even that can be very drivable with the right tune.
Not sure if you are planning on doing the swap yourself but having just done it I can tell you that it is cake. I took my time, ran into a couple problems and still had it done in great time. If you have any questions now or during the process let me know and I will do whatever I can to help.
With stock gears dont go over a 230, yea you can get a trex cam put it in but will it be optimal nope. Smaller cam will give you a nice tq curve and more usable power. Sure you can get a 230+ gear and to get the most out of it throw in 4.10s etc but then your right were you dont want to be. Do searches you can find many videos of small cam set ups hading a huge cammed car its ***. I personally would do a vengence vrx3
Smaller cams dumdumdum
About your cam dilemna, I wouldn't be too worried about reliability and longevity, as long as it's done right. Like most have mentioned, no need to go with a huge cam for your needs. Get something around the 224-228 range, and you should be very happy. It's all in the tune. I have a 222/224 (wish I went a touch bigger, 228...) and other mods, and the car pulls very hard, but is still extremely driveable in all kinds of traffic. I daily drive my car and other than some fuel pump issues (even after the 255 LPH) the car hasn't ever given me a problem. Took a while to finally get the tune on point, but that was because of software issues, a minor vacuum leak in the PCV hose, and a tweak to my PCM "fingers", the car is now running better than ever.
Good Luck, and I say go for it and don't look back!!!
