Window replacement write up?
http://shbox.com/1/adj_window.html
Its a write-up on how to adjust the window.
You remove the door panel
instead of drilling out the motor rivets, you drill out the rivets where the plastic pieces attach to the window. Replace the window and using 1/4-20 bolts and washers (and loc-tite) tighten the bolts up by hand and put the panel back on.
