2002 formula firehawk nbm
car has 88k miles
cloth interior
origional wheels
never been wrecked
mods:
d1sc procharger 8rib
Jet hot long tubes
patriot ls6 heads
comp cam livernoise springs thunder pushrods
stock bottom end
custom pvc system
battery relocation
line lock and abs delete
magnaflow exhaust with corsa tips
manual exhaust cutout
Rpm 4l60e(best one they make hardened output shaft)
vig 3600 stall
aftermarket driveshaft(rated to 1000 hp)
Moser 12 bolt true trac rear
aftermarket rotors and hawk pads
suspension:
bmr track pac
umi double ajustable pannard bar
spohn on car adjustable lca's
slp sub frame connectors
autometer gauge pod and gauges
car made 460 on a mustang dyno with converter unlocked at seven pounds
car is in great shape and is always been well taken care of
it has the normal small chips and scratches for a car with this milage that has been daily driven
New tires
just wondering what it was worth if someone purchased it as is
