95 Firehawk
95 pontiac Firehawk #195 red w/ gray leather, 68000 miles,6-speed,410s, T-tops,Y2K vette rims,lojack, ls1 brakes,cross drilled rotors,TA high rise hatch and stock hatch, 40 over with KB forged pistons,scat rods,scat crank,comp cams extreme grind cam and vacuum canester,comp cams magnum roller rockers and valve springs,chrome valve covers,LT4 KM, hooker headers and Y-pipe,aluminum driveshaft,accell,taylor metal wraped plug wires,edelbrock panard bar,edelbrock torque arm,edelbrock lower control arms,everything is new on the motor ,aeromotive fuel pressure regulator, the car needs minor body work,paint,driver headlight motor,shifter boot,wire is broken on speed sensor 678-525-4728 I also have A garage full of stock parts
http://good-times.webshots.com/photo...79665766Rzzpoo
