2002 camaro
Old Apr 6, 2009 | 03:10 PM
gbjr08's Avatar
Default 2002 camaro
specs and mods
2002 Z28 Camaro w/ 30xxx on the odometer. It has black leather interior and is a T-Top. Its LS1 motor balanced with ARP rod bolts. It has light weight pistons. It has ported and polished heads with swirl polish valves. It has titanium retainers, roller springs, and comp roller cam. It has a 520 lift by 220 duration. It has 114 degree lobe center. Chrome alloy push rods. 85 millimeter throttle body. 300 HorsePower adjustable NOS. D & M pro ratchetshifter. Bullet proof stage 3 turbo 350 with a loose converter. big tube coated headers. Rear suspension. 12 bolt 342 posi track. Brand new Mickey Thompson cheater slicks and much more. Legit high 10 second street car off of pumped gas, without ever hitting the Nitrous. Factory AC, AM/FM radio, CD, Power windows and door locks.
Old Apr 6, 2009 | 04:35 PM
Bill'sWS6's Avatar
Originally Posted by gbjr08
specs and mods
You may want to edit your post. There is no way with the cam specs you listed this car will get ANYWHERE near 10 sec. The cam specs you listed can't be right.
"It has a 520 lift by 220 duration. It has 114 degree lobe center"
520 Lift, don't think so, not on an aftermarket cam.
220 duration, again, not likely on an aftermarket cam.
114, yep, very likely.
Take a look into those specs and edit. If you say they are correct then you are not going to be close to that 10 sec time.
Good Luck W/Sale. I will Take A Look At The Pics When I Get Home.
Where Are You From?
Bill
