Turbo SS - How much
Old Jul 13, 2009 | 05:49 PM
calongo_SS's Avatar
Default Turbo SS - How much
I'm contemplating selling by car here's the details:
2001 SS, one owner, 65k miles, stock bottom end. The car runs great, fires right up, uses almost no oil.
The car is in reasonable shape, but it was my DD for years and it shows. Has a few scratches, and some swirl marks, but it cleans up pretty good. A/C and all the options work.
Now on to the fun stuff:
APS Twin Turbo kit
Alchy Control Meth Kit
Small turbo cam, dual springs, ti. retainers, etc.
BMR turbular k-member
Strange DA front shocks
Competition engineer rear drag shocks
Spohn chrome moly spherical rod ended LCA's
Spohn drag anti-sway bar
BRM Torque arm
BMR trans x-member
FLT Level 4 4L80E w/ vac. modulator
Vigilante 3600 stall
Moser 12 bolt, 35 spline axel's, spool
UMI LCA relocation brackets
BMR adjustable upper PHR
Custom 3" x pipe dumped
Prostars all around (10" in the back)
Battery relocation
SJM line lock / ABS delete
A-pillar gauge pod w/ LC1 wideband, boost and trans temp gauges
Double pumper fuel kit, 60 lb injectors, FAST fuel rails
HP Tuners 2 bar OS w/ GM 2 bar MAP
I will also likely include HP Tuners (no credits left, but works on this car)
The car has been running like this for quite a while, it made 585 rwhp on ~10psi, and went 10.5 @ 131. Other than a built bottom end and heads there isn't a whole lot left to be done to this car if it's going to stay a street car.
What do you think I can get for it?
Old Jul 13, 2009 | 06:13 PM
mitahuoch's Avatar
just by the mods and the mileage you have on your car, Im gonna throw a number out there. Im gonna guess you might get around $18,000 for the car. but look at how much you put into the car. well over $15,000 im guessing??
Old Jul 13, 2009 | 06:52 PM
calongo_SS's Avatar
Yes, probably around 15k in mods.
