99 trans am roller
Old Aug 7, 2009 | 02:36 AM
rwhockey29's Avatar
Default 99 trans am roller
is this worth $1500? (i tried posting in the "whats it worth", but not enough posts)
1999 Trans AM 10 point Mild Steel Wolfe Racecraft Roll Cage .
Complete Mini Tubs installed
Wolfe Torque arm cross member
Auto meter gauges, , Oil , Temprature, Amps
BM pro stick shifter for Powerglide
Removable Grant steering wheel
BMR sub frames,
Massive Weight reduction all over car.
Transmission cross member set up for power glide.
Race car wiring harness,
Engine bay painted,
Set up for fuel cell in rear hatch area.
Solid Mounted front headlight panels
Working Drivers door Electric window with new motor
IT has no engine or transmission and only a roller rearend
the outside/inside are in great shape
thoughts??
Old Aug 7, 2009 | 02:44 AM
lemons12's Avatar
BMR sub frames,
Engine bay painted,
thoughts??
if the body is straight and its in decent shape its worth more than that.. what kind of rear end? 10 bolt?
Old Aug 7, 2009 | 02:54 AM
rwhockey29's Avatar
not sure, but it said it only has a roller rear end so id have to replace it.
its def in good shape, i waas suprised, most rollers i see go for around 2.5K, without all the goodies
now i just gotta figure out an engine to put in. i need lots of power, if i have a cage
Old Aug 7, 2009 | 03:06 AM
lemons12's Avatar
heres some good choices..
http://texas-speed.com/shop/item.asp?itemid=42&catid=27
http://texas-speed.com/shop/item.asp...d=683&catid=83
http://texas-speed.com/shop/item.asp?itemid=43&catid=86
http://texas-speed.com/shop/item.asp?itemid=46&catid=28
just depends on what your pocket book can do..
my next build will be a 347 or a 383... will be lite as **** and going to spray the **** out of it.. im going to shoot for 6.teens... hope for 5s..
Old Aug 7, 2009 | 03:10 AM
rwhockey29's Avatar
well, being 18, working part time, going to school, and working on a truck doesnt give me THAT much lol. im looking at a budget build, and im shooting for 500hp, maybe 600
i found an lq9, complete out of a escalade, so its the high output. i can get it for 1k, and i was thinking of making it a stroker, roller rockers, cam, intake manifold, ported/polished heads, longtubes, then straight pipes. but idk yet the engine is still pretty far away. luckily, im going to school for auto repair so i can do all the labor myself.
i might just buy a junkyard ls1/ls2 and build that up. idk..
Old Aug 7, 2009 | 03:15 AM
lemons12's Avatar
ahhh, on a budget! we all are!
id go 6.0l. PRC stg 1s, ms4 cam, ported 9090, pacesetter LTs with xpipe before the axle, 410s, 4000 stall.. something along those lines and spray it with a 150 shot..
should put you deep into the 10s...
Old Aug 7, 2009 | 03:18 AM
rwhockey29's Avatar
well, my budget is all little more constricted lol
sounds good, but im planning on it being a manual.lq9 is a 6.0L correct> or would you recommend a different block?
Old Aug 7, 2009 | 03:24 AM
lemons12's Avatar
ahhhh damn.. so you just want it to look/sound fast but not be fast!?
yes, that is correct.. that is a very good block to go with.. cheap/reliable..
i know a buddy who can get complete drop outs with under 40-50k miles and a 6 month warranty for like 1200$ or something like that..
you were talking about stroking it.. so instead of that you could do what i said..
heads/springs 950
pushrods 80
timing chain and oil pump 150
cam 250
dyno tune 300
ls6 intake 300
LTs/ypipe and cutout and extensions 350
gears 250
fuel pump 100
nitrous kit any where from 250-600
rough estimates real quick for you.. used prices.. might have left a thing or two out..
Old Aug 7, 2009 | 03:33 AM
rwhockey29's Avatar
heads/springs 950
pushrods 80
cam 250
dyno tune 300
ls6 intake 300
gears 250
fuel pump 100
yea, my friend from ricekiller can get them for 1200, he works at a dealership.
so, about $3000 into the engine? thats not too bad
what would you recommend for a trans? id like a 6spd manual. just a stock one out of a trans am/camaro?
Old Aug 7, 2009 | 03:38 AM
lemons12's Avatar
yea, if you watch for deals you could do all the engine/exhaust for 2500 bucks..
i would recommend not getting a six speed..
if you absolutely HAVE to have a six speed.. you need a clutch, ls6 at minimum.. but thats not going to last long.. shift forks.. etc.. i dont know a lot about t56s so im not going to say much on it.. you can get a4s for dirt cheap and they hold out pretty good at decent power levels.. plus they are faster.
Old Aug 7, 2009 | 03:49 AM
rwhockey29's Avatar
understood, i just want a manual trans for my car, the truck is auto. lol
this is gunna be a weekend car when finished, not some track car. my goal is to have it to where i can take it out on the weekends, and cruise, and kill the majority of lightly modded cars i run across, or give some good runs. my group drives gt's srt4's camaros and T/A's just wanna be able to hang with them.
im not really worried about the clutch, because i wont be stepping on it alot. i mean, not full throttle, double shifting type of stuff. it might see one or two track runs, just to see what it can do
Old Aug 7, 2009 | 03:54 AM
lemons12's Avatar
one track run with that setup on a stock t56 would probably demolish the trans..
if your not looking for the fastest thing on the road then i would not buy expensive heads.. some stock ls6 heads or if you really want to go cheap some stock 02 ls1 heads will do the job..
Old Aug 7, 2009 | 03:57 AM
rwhockey29's Avatar
what kinda power would i be looking at if i went with that setup with those heads, compared to ls6 or ls1 heads?
ill prolly end up buying whatever i can find on sale at the time lol. unless its a HUGE difference
Old Aug 7, 2009 | 04:04 AM
lemons12's Avatar
with that setup and PRC stg 1 ported ls6 heads.. 440-450rwhp..
that setup and stock ls6 heads.. around 420-430rwhp..
that setup and 02 ls1 heads.. 410-420rwhp
all are ball park/average numbers... setups will vary.
Old Aug 7, 2009 | 04:12 AM
rwhockey29's Avatar
450 sounds nice lol
what kinda shot could this handle? 100 for daily driving?
Old Aug 7, 2009 | 04:15 AM
lemons12's Avatar
450 sounds nice lol
yes, it is..
well, doesnt really matter what size shot you run because you just use nitrous when you want..
you could "safely" run a 175 shot.. 200 is the limit on a stock bottom, but many people have ran many passes on this size..
a 100 shot would be a very conservative shot..
running around town i would use a 75 shot.. if i knew i was probably going to race or i was looking for some fun i would swap in the 150..
Old Aug 7, 2009 | 04:31 AM
lemons12's Avatar
https://ls1tech.com/forums/lsx-parts...d-springs.html
Old Aug 7, 2009 | 10:37 AM
rwhockey29's Avatar
yes, it is..
i didnt know how well these engines stood up to nitrous, i know my 5.9L can handle a 200 shot, although its a heavy duty engine lol. i was thinking a 125-150 shot, just left in, incase i found a mustang or something
wish i could afford them, but i need the car first lol. those are the ones i was looking at actually
i checked, and its got a shifter setup for a powerglide trans. should i just go with this, would it be better then a 6spd?
Old Aug 7, 2009 | 11:25 AM
406malibu's Avatar
Lemons, I agree about the clutch, shift forks, keys, and other weaknesses of the T-56, but if shifted easy with a good clutch it'll still last longer than the 4L60E. that trans is crap. course if he was to put a 4L80E, thats a different story...
Old Aug 7, 2009 | 12:49 PM
CO99Z28Vert's Avatar
Damn I would love to find a really nice roller Trans AM, I am getting kind of tired of a Convertible and would just take all my goodies off of mine and swap it all over.
I cant seem to find any good rollers around me.
