2 part question concerning hci 9 inch rear 2000 transam
2000 trans am 6 speed 103k on the body (0 miles on motor, trans & rear end)
6 speed rebuilt in october 08
ported 5.3 heads with prc 660 springs and titanium retainers and steel locks
polluter cam deluxe kit
slp underdrive pulley
msd wires
lingenfelter intake manifold
3 inch true dual's with x pipe summit glasspacks and custom silencers
ford 9 inch with 4.11 gears and spool
steel driveshaft
percy's speed glass front and rear
abs delete and line lock with shifter switch
umi tq arm
lakewood lower control ams
hotckiss pan hard bar single adjustable
scat race seats
Pro 5.0 shifter and hurst pistol grip handle
bmr kmember
umi tq arm relocation kit
polly motor mounts and tranny mount
walboro 255 intank pump
hooker longtube headers
ford cobra 42lbs fuel injectors
weld prostars 15/4 up front
weld prostars 15/10 in the rear with brand new mickey thompson et street radials 325/50/15
(spare brand new et streets bias ply 28/11.50/15)
homemade stealth sub box
tb bypass
ported 85mm truck maf
ported 80mm bbk throttle body
slp lid
nkg tr6 plugs
pcm forless mail order tune(temporary if I keep the car)
ac delete
tcs delete
cruise control delete
windshield washer fluid resevour delete
rear seat delete
both air bags deleted
qa1 single adjustable 12 way front shock plus 300lbs springs
competition engineering rear drag shocks with stocks springs on the rear and heater hose mod
24 mm rear sway bar from a 3rd gen ws6 car
polly sway bar links and pushing front and rear
brand new brakes+ rotors all around
powersteering delete
manual fan switch
wilwood porportioning valve for brakes
zoom clutch and stock flyweel new slave and master
wiring harness has been gone through and unessacary connectors have been deleted
front and rear bumper delete
ls2 timing chain and gears
ported and shimmed ls6 oil pump
door bars delete
ls7 lifters
wolf 6 point cromoly roll bar installed
ls2 coils added
thats all the good now unfortunatly there is some bad
the upper center console should be replaced
the front bumper cover needs to be repainted
the carpet is showing its age (replacing it with ozite in 3 weeks)
it needs an alignment (if I still have the car in 1month this will be done as well as a 5 point harnesses )
missing stereo head unit and front speakers(will be getting these soon if I still have the car in a month)
emblem deletes exterior door trim delete( good or bad depending how you look at it)
what do yall figure it is worth the way it sits now?
second question is If I pull the motor /tranny and wiring harness and sell it as a roller what is a fair asking price btw I would be keeping the duals with the car and possibly the headers as I would have no use for these with my plans for a c3 corvette
