370 soild roller motor
4k miles on the longblock
370 solid roller motor.
Motor:
6.0 block 4.030 bore
stock crank – prepped/polished
wiseco pistons w/ valve reliefs
callies on center 6.125 rods, ARP bolts
federal mogul main bearings
clevite rod bearings
double roller timing set
ARP main studs
ARP 12 point head studs
GM 6.0 MLS gaskets
Morel solid lifters
248/254 .694/.697 112lsa solid roller Comp cam
Comp High Tech pushrods
10.6 : 1 compression
Heads:
317 castings, for 4.030 bore
2.080 Ferrea Competition series intake valves
1.600 Ferrea Competition series exhaust valves
Isky Gold Stripe 1.550'' dual springs w/ damper
CV products super7 retainers/locks
GM valve seals
Jesel J2K Mohawk rockers w/ custom 1 piece shims
C5R valve covers
The motor has roughly 4K miles on it, almost all highway, no track time.
