99 WS6 with tons of mods
0 miles on build
prc 5.3 2.5 heads,v2 cam hardened pushrods ls6 intake ported throttle body ls7 lifters, arp rod bolts,ported ls6 oil pump ls2 timing set all new engine gaskets underdrive pulley,slp lid 85mm MAF ptc th350 set up with 3800 converter,trans cooler, percision shifter, tci flexplate, ultra lite gauges trans oil pressure and airfuel, pacesetter headers and y borla racetronics fuel system with hot wire, drilled and slotted brakes new pads and all, y2k vette wheels OEM 17/18 with drag radials, UMI on car adjustable LCA and PHB body mounted torque arm UMI UMI k member. 373 gears with new bearings seals and gasket complete nitrous kit 78 mm nitrous plate system purge heater switch panel billet bottle bracket with custom painted bottle black leather interior paint is flawless as well as interior
car was originally a M6 car
car will be completed by end of next week what should i ask for the car?
