Modded 04 Avalanche Z-71
Old Jun 7, 2010 | 01:50 PM
dhpro's Avatar
Default Modded 04 Avalanche Z-71
$30,000 - Z-71 Full Factory option package
BAER brakes - 4 corners (6 Piston, 15" fr, 14" 2 Piston rr) w/ SS lines;
370 Hardened Motor - Diamond Pistons, Eagle Crank & rods, Patriot Springs (complete build sheet avail) maing ~550rwhp/600torq
MP122 HH Blower w/ CTS-V heat exchanger, Innovators 8 Rib kit (10% O/D crank) making ~10lbs boost - + spare pulleys!
Alky Control Meth kit & return style fuel system w/ regulator & KB BAP
3" true duals w/ Dynatech LT's & custom x-over, gutted cats - Its loud!
20" AMR-RTS wrapped w/ TOYO 305-50/20 (less than 1000 miles) - I have a set of OEM 17" wheels and AMR 17" that I'll throw in but wont fit over the brakes...
Built 4L80E w/ Vig 2600 (serviced <600 miles ago with new cooler & lines added)
BlackBear Tune (runs like it was meant to!)
E-fans w/ Nelson Harness - all relays recently changed
New Ring/Pinion (Brand spankin ****** new!!!) 7 auburn gear locker
Edelbrock Performer Shocks on 4 corners (<500 miles)
Edelbrock Trailing Arms (<500miles)
Edelbrock PanHard Bar (<500Miles)
Eiback Sways - fr & rr
DJM 2" drop springs, w/ shock extensions (Trailing Arms shackles incl if u want them)
