Mostly stock 96 A4 SS.
Just getting a feeler for what its worth. I have a 96 Camaro SS A4 with 106,xxx miles. Its car #869 of about 2400 built in 96. Its red with black leather interior that is in good shape yet. It has the the slp options of Level II suspension, torsion II dif, SS floor mates, 17 inch ZR1 SS wheels, SLP high flow catback (but has since been replaced with a Borla) and it had a SLP SS car cover but that is gone. Its a hard top and has RK sports black stripes down the length of the car. The trans was supposidly replaced with a reman from GM but I have no paperwork for that. It does shift good and it must have a shift kit in it.
I replaced the driver side power window motor but also need to replace the passenger side. The headliner is sagging and it needs an alighnment here soon. Other than that the car is strong and holds good oil pressure when hot and cold. Cold is around 60psi at idle and on a hott day at idle is around 15-20psi. which is good for a LT1 with over a 100k.
So what do you guys think I can get out of it?
