97 WS6 auto
Old Sep 10, 2010 | 06:32 PM
Enforcerws6's Avatar
Default 97 WS6 auto
Car has 72k miles and in the 4 years i have owned it only got 4k put on it the rest of the time it was stored in the garage. only rust on the car was the underside parts that gm was too cheap to paint good enough like the front a arms etc
52mm bbk throttle body
what i have done to the car since owning it
moser 9" 3.70 gears with weld on relo brackets
pacesetter coated lt headers off road y thru a LM1 yep its loud
abs delete and line lock with the steering wheel button controlling the line lock
umi adjustable rear suspension lowers pan hard
umi body mount tq arm with drive shaft loop 3 point sub frame connectors
aftermarket alum driveshaft
Ion tune runs 13.5 at 102 with this tune
car is lowered rears or Strano springs and koni adj
front is lowered but never got the koni purchased yet but have the strano springs for it not sure what springs are on it now
big trans cooler but still has stock stall and trans
lots of custom stuff done here and there and done right not hacked.
im sure im forgetting lots of things but what is it worth approx as i am hurting for money and may have to sell it.i was building this car to be close to bullet proof as possible from back to front but never made it to the trans or engine yet.
