Modded 99 HOSS
1999 Hugger Orange SS, M6, Ttop, Gray Leather Interior
The mods are from memory, I may be leaving out a few things, but the car is covered and the list is inside and I'm lazy right now.
Engine Mods:
TRak Cam
Comp 921's
FAST 90 MM Intake/90 MM TB
ATI Damper
LS6 Oil Pump
Exhaust Mods:
Pacesetter Longtube Headers
Catless Y-Pipe
Electronic Cutout in the I-pipe
Stock SS Exhaust with B&B Tri Flow Tips
Drivetrain Mods:
Textralia OZ700 Clutch
Some type of upgraded rear differential cover, silver in color with pre-loading screws.
Suspension Mods:
BMR Front and Rear Sway Bars (Hugger Orange)
BMR Adj. Torque Arm (Hugger Orange)
Tubular Rear Control Arms
BMR Bolt in Control Arm Brackets (Hugger Orange)
BMR Fixed Panhard Bar (Hugger Orange)
Eibach Pro-Kit Springs
Appearance Mods:
Gloss Black Rear Panel
Orange and Silver Brake Calipers
Drilled and Slotted Brake Rotors
Chrome 17x9.5 and 17x11 ZR1s with SS Logo
Custom Painted Black and Hugger Orange SS Grill with Stainless Wire Mesh
Chrome SS Hood Vent Insert
Dark Window Tint (not sure of percentage, but its not legal)
Gloss Black
Misc. Mods:
Wire Mod
Painted Valve Covers (Gloss Black)
Painted Coil Packs (Hugger Orange)
Pro 5.0 Shifter
Lous Short Shift Stick
C6 Shift ****
Custom Painted Interior Dash Panels (Silver)
Silver SS Gauge Overlay
Harlan Shift Light Located in the Drivers Side Circular Window Vent
Dual Gauge Pod with Oil Temp. and A/F Ratio Gauges (Silver Gauge Face)
Walbro 255 Fuel Pump
Some type of upgraded fuel injectors
JL 10' Sub with Stealth Box
250 Watt Amp?
Car has won several awards at car shows for best appearance, paint, engine bay etc. I'd say the paint is a 9 along with the interior. It dynoed 430/393 I believe several years ago. It has been tuned by my buddy WS6FirebirdTA00 and is on an open loop tune. I have an 85mm MAF that I can have put on and re-tuned. The mileage is 131,xxx. The valvetrain probably has a total of 15k on it. Car runs very well and has no problems at all except for a small oil leak coming from the oil pan. Its sat for 6 months before and there was no indication from the dipstick that the oil was low. Thanks for the help guys.
Good luck man.
