2001 ws6 t/a lq4
1st off 2001 WS6 T/A 103,000 miles, new arctic white paint with blue pearl. 18" Boyd Coddington Smoothie II's new tires in front and rear with MT drag radials in rear. Interior about an 8/10. Carpet could be shampooed.
Now the good stuff, stock LQ4 bottom end with PP CNC 243's, harland sharp roller rockers, Fast 90/90, lucas 43lbs inj, billet fuel rails, FIPK K&N, pace setter long tubes, msd wires, true duals, 255 LPH walboro with racetronix hot wire kit, just about every bolt on, underdrive, 85mm maf. machined valve covers. it hasnt been to the dyno and it has a TSP mail order tune.
Performa built level2 trans with a TCI 3500 stall, ME 12 bolt with 35 spline spool abs delete with line lock, weld in sub connectors, eibach lowering springs in rear. long style wheel studs in rear, new struts and shocks, i also have a full urethane front end kit but its not installed yet "but will be soon".
clean title and i think im the third owner. ill try and get a pic up soon.
For starters, you would be better off selling the rims/ tires for good money then buy a stock ws6 rims and tires set for around 350-450.
Keep in mind it's winter and demand is very low right now.
