'01 camaro ss details inside
7,000 on tires great shape not abused
Tuned PCM by Tunedbyfrost then dyno tuned w/ hp tuners (2 hours worth but could always use tweeking)
Pacesetter 1 3/4 headers
walbro 255 lph fuel pump
new rings, crank and rod bearings
ARP Rod Bolts
cam 232/236 .601/.601 112 LSA
Lunati Lifters
TSP 7.4" hardened push rods
Cloyes billett timing chain
Ported LS6 oil pump
MLS head gaskets
.241 head casting milled .010, valve job, bowl and throat blend
PRC dual valve springs .675
LS6 intake
fast 42lb injectors
all new engine gaskets and sensors(throttle position sensor, idle air control sensor, O2 Sensors included)
ls2 style starter
spec stage 2 clutch
motive 4.10 gears
rear end rebuilt with Ratech bearings
air lid
E3 Spark plugs
New brakes (nothing spectacular)
New Factory MAF sensor
on dyno
