Looking for Opinions on the value of my TA
Engine Modifications:
Factory Bottom End
Trick Flow 220 as cast heads (dual valve springs, powder metal valve guides, titanium retainers)
MLS Head gaskets
ARP Head Studs
Factory Rockers w/ Comp Cams Trunion Upgrade
Tick Performance SNS Stage 3 Cam (235/243 .62x/.62x LSA 111+2)
Tick Performance 7.500 hardened pushrods 5/16” diameter .080” wall
Morel 5315 Hydraulic Roller Lifters
Melling High Pressure (standard volume) Oil Pump
Cloyes Adj. Timing Set
LS6 Valley Cover
SLP 160 Degree Thermostat
Norris Catch Can
Induction:
Fast Toys 104mm Lid
GM 85mm MAF ( 5.3L truck MAF)
Nick Williams 92mm Throttle Body
Fast 92 Intake Manifold
Exhaust:
American Racing 1 ⅞ Long Tube Headers
American Racing 3in Offroad Y-Pipe
Magnaflow 3” Cat Back
Fueling:
Racetronix 42lb Injectors
Speed Inc High Volume Fuel Rails
Racetronix F99 FPA-001B Fuel Pump (the purple pump)
Racetronix Fuel Pump Hotwire Kit
Drive Train:
Monster Stage 2 Clutch with 28lb Flywheel (new GM slave/pilot bearing)
Tick Master Cylinder
MGW Short Throw Shifter
Strange S60 w/ 4.10 gears, S-Track (posi), 3 channel
Strange Driveshaft
Suspension:
UMI Torque Arm with Tunnel Brace Relocation Bracket and Driveshaft Loop
Founders Adj. Lower Control Arms and Adj. Panhard Bar
UMI Rear Sway Bar
Koni Shocks w/ BMR Lowering Springs
Founders Strut Tower Brace
Chassis:
Founders 2 point weld in Subframe Connectors
Wheels & Tires:
Rear Wheel: 17X11 American Racing Torque Thrust II
Rear Tire: Toyo Proxy TQ Drag Radial 315/35/R17
Front Wheel: 17X9.5 American Racing Torque Thrust II
Front Tire: Toyo Proxy
Items Deleted:
Catalytic Converters
Air Pump System and EGR
LS1 PCV system (replaced with LS6 style system)
Fuel EVAP System
Power Steering Cooler (replaced with Derale P/S Cooler Kit)
Great driving car tuned by Pat G on his dyno. I have all of the tune files and EFI **** to go with the car. It put down 432/395 on his dyno. Its insured, it passes inspection in TX. Not quite sure I am going to part with it but I was looking for options on the price I should ask if I do. Anyway, sorry for the book. Any input would be great.
Build Thread: https://ls1tech.com/forums/pontiac-f...tle-build.html
