97 TA worth
Wondering thoughts on an 1997 Trans Am non WS6, Auto, T tops, 50K miles, excellent paint, body, interior. Color is Green with Taupe interior. Runs out great. Any ideas on a ballpark? I’m contemplating..
I'll say that a one or two owner garage kept example with those low miles, that needs 'very little', will command a price north of $10k these days. No doubt about it. Can you provide more info??
Clean Title, needs tires and AC not currently working. Other than that a very clean, stock car. No cutting or mods anywhere.
But I agree on $10k-ish. Being an LT1 takes it off the list for many, also being an auto. But, if you want an auto the LT1 is a great engine and sounds great even with just a cat back.
If it hasn't had everything like transmission oil and filter change, rear end flush, coolant flush, brake fluid change, I'd drop the price about $2k. If it been done half way recently that's different.
Do NOT pay too much for this car, and I would recommend a pre-purchase inspection by a mechanic You don't want to be into this car for $10k and then need $5k more within the first year. Good luck!
26 year old car - AC not working, Automagic Transmission
AC could be as simple as the belt removed, broken - with 50K miles probably needs a recharge.
Big plus here is the low miles.
Good luck buy it right and you will be happy!!!
