whats the value of this car?
CAR...as it says. bodys in pretty good shape. its got one scratch by the pass rear tire. it was tuned by vector motor sports in detroit.
MOTOR
-402 iron block stroker(slp)
-cam is a .590 in/exh 236/236 lobe seperation and centerline are 112 degree
-afr heads with 2.08 intake and 1.60 exh.
-slp long tubes with a 3in catless Ypipe, cut-out, goin into a 3inch cat back
dynomax.
-msd ignition coils, msd wires.
-weiand polished alum. intake
-a/c delete
-slp cold air lid
-red top optima battery
-NOS wet plate kit. 150 shot with purge ...bottle in passenger rear seat.
TRANS
-auto 4l60e completely built for abuse
-vigilante 3200 lock up style converter with anti ballooning plates for spray
-b&m trans cooler
-alum. drive shaft
SUSPENSION
-bmr shorty adjustable tourqe arm
-bmr lower rear control arms
-bmr subframe conectors
-bmr pan hard rod
-stock springs and shocks in front
-sotck springs and comp engineering 3 way ajustable drag shocks in rear
-bmr strut tower brace
OUT BACK
-moser 12bolt
-373 gears
-33 slpine axles
-moser diff cover with girdles
EXTERIOR
-zr1 kock offs .chrome
-17x11 in rear with nitto extream drags
-17x9.5 in front with nitto nt555
-ws6 hood with custom grill inserts
INTERIOR
-wolf 6 point powder coated black race cage, with swing outs. bolt in/weld
on cage.
-trans temp, nos, and aem wideband guages.
any ideas?
