Widened Ws6 Wheels
Old Oct 14, 2008 | 10:44 PM
NVR_SPDS's Avatar
Stock WS.6, and SS wheels are 17x9.
Heres some pics from the prior owner of the car: Stock 00 WS.6 wheels, clear coat was stripped off, and widened to 11" with a spacer in the rear with 315/35-17 Nitto DRs:
Old Oct 14, 2008 | 10:49 PM
blackesteyes8696's Avatar
I've seen the newer style ws6 wheels widened and it looks bad ***!
Old Oct 15, 2008 | 07:35 AM
Randy WS6's Avatar
My WS6 wheels are widened to 11" by Wheels America in Miami FL. 450.00 and they supplied the extinction.
Old Oct 15, 2008 | 10:36 AM
ZFSix's Avatar
NVR SPDS:
I see the Texas plates, was the previous owner named Ron? If so, I sold him those tires when I worked for Discount.
I'm guessing it is because his car was identical to that. Very clean car.
Old Oct 16, 2008 | 02:02 AM
NVR_SPDS's Avatar
Originally Posted by ZFSix
NVR SPDS:
Sorry to get off topic, but yep, i traded my 04 Lighting to Ron for the car.
Old Oct 16, 2008 | 04:29 AM
_916ls1z28_'s Avatar
iknow cuz if there only 9'' i have 315s on 10 spokes out back...... ill have to remove them sorry for high jacking thread
Old Oct 16, 2008 | 02:39 PM
colby72olds's Avatar
What?
Old Oct 16, 2008 | 03:19 PM
SLOW30th-TA's Avatar
Originally Posted by colby72olds
What?
I think what he was saying was that he had 315's on his stock 10 spoke SS wheels that are only 9 inchs wide....which is unsafe...https://ls1tech.com/forums/wheels-tires/120716-wheels-tires-everything-you-should-need-know-here-must-read.html
Old Oct 16, 2008 | 04:22 PM
DevilDougWS6's Avatar
there is a place in jersey that does ANY custom wheel work. i was thinking about getting mine widened to run 315s. what else would be required to run this size rim/tire? fender roller and a spacer? is there a better way to do this without a spacer?
Old Oct 18, 2008 | 12:23 AM
BubaGumpShrimp's Avatar
would like to know as well
Old Oct 18, 2008 | 06:05 PM
rossina00's Avatar
From What Ive Gathered There Isnt And Ive Been Bashing In The Inner Fender Cutting And Youll Need Spacer Bcuz The Off Set Of The Factory Wheel.
Old Oct 20, 2008 | 12:45 AM
  #32
Originally Posted by SLOW30th-TA
I think what he was saying was that he had 315's on his stock 10 spoke SS wheels that are only 9 inchs wide....which is unsafe...https://ls1tech.com/forums/showthread.php?t=120716
Yes thats what i was tring to say ........true that blood lol
Old Oct 20, 2008 | 05:42 AM
  #33
Randy WS6's Avatar
I have mine on a lowered car, I had to remove the bump stop and remove some metal around the coil spring and roll the finder lips and hammered the inside the finder well. And used a 7/16" wheel spacer and longer studs. Ans a adjustable pan hard rod.
Old Oct 20, 2008 | 07:00 AM
  #34
02Z28LS1's Avatar
Originally Posted by Koastie57
mine are 17x9.5 and they're stock..
no.
if they're stock as manufactured from GM directly (i.e., has a GM logo stamped into the casting), they are 17x9.
if they truly are 17x9.5, then they are replicas, and will not have the GM logo stamped into the casting.
you don't measure the wheel from the outside edges of the rim lips, you measure them from the inside, where the tire bead meets the wheel lip. that can easily account for .5"
Old Oct 20, 2008 | 07:42 AM
  #35
ZFSix's Avatar
Originally Posted by 02Z28LS1
no.
Or just look on the inside of the wheel, the size is stamped on there.
