BS/Offset?
Old Oct 13, 2008 | 01:59 PM
LT4POWR's Avatar
Default BS/Offset?
Given that the popular Grand Sport (rear) wheels spec at:
17" x 11" (+50mm offset/7.93" backspacing)
Now, here's my (incorrect) math:
rim width...11 / 2 = 5.5 wheel centerline
backspacing - centerline = offset in inches (convert to mm)
7.93 - 5.5 = 2.43
convert (2.43) inches to mm should be (2.43x25.4) is 61.72mm offset
but the offset s/b 50mm
What am I doing wrong? Thanks
Old Oct 13, 2008 | 02:16 PM
Xsta Z 28's Avatar
Offets does not include the bead thickens of a wheel . . . where the BS does . .
Thus BS and Offset are RELATED but you cannot really 'guess' one from the other . . .
Average bead thickness of a wheel is anywhere between 3/8" to 1/2"
The offset is calculated from the advertised rim width, which is the distance BETWEEN the beads.
Backspacing is calculated from the full overall width of the wheel, where an advertised wheel is 11" it will have an overall width of up to 12", including the mounting beads.
Think of a wheel as a channel like this " [ " where the advertised width is the inside distance between the two little legs and the overall is to the outside of the little legs.
Offset = 50 mm which equals 1 31/32" or 1.96"
11" divide by 2 to get center line of wheel is 5.5"
5.5" + 1.96" = 7.46"
Advertised Backspace of 7.93" - 7.46" gives a bead thickness of .47" or 15/32" . . .
Make sense?
Old Oct 13, 2008 | 02:28 PM
LT4POWR's Avatar
Make sense?
yep, makes sense, thanks
sure would be nice, if they (offset & bs) were calculated from the same point!
