If they fit on a third gen...
Old Sep 15, 2003 | 10:39 PM
SmokinZed's Avatar
Default If they fit on a third gen...
I got an old pair of 15x4 skinnies from a local kid dirt cheap($15.00). I think the back space is 3.5" is but he said they fit on his third gen without a problem or spacers. Will these go on with no problems?
Old Sep 15, 2003 | 11:13 PM
JimmyKash's Avatar
Default Re: If they fit on a third gen...
i highy doubt the backspacing is 3.5" on a 4" rim.
Usually the backspacing is 1.75" and should fit with some grinding and/or a small spacer
Old Sep 15, 2003 | 11:18 PM
SmokinZed's Avatar
True.. b/c it worked on this 3rd gen is there a good chance itll work on a 4th gen with little trouble?
Old Sep 16, 2003 | 06:48 PM
trackbird's Avatar
It will probably hit the caliper. YOu may need a spacer to get it to clear properly. Depends on which wheel it is.
