Question about Wheel weight...
Old Nov 5, 2008 | 10:05 AM
cowboyup's Avatar
Default Question about Wheel weight...
I have an '06 C6 with stock silver 5 spoke wheels.. they weigh in at 22lb each..
I am getting wheels that may be a little heavier.. like 26front and 27 rear..
Willthis make a difference as far as rolling mass?? will 18lbs make that much of a difference??
Thanks...
Old Nov 5, 2008 | 11:12 AM
jjordan's Avatar
Let's face it, we all know it won't help it any, but on a DD I doubt if you will notice. Usually have to get to the track with back-to-back runs to document the change.
Old Nov 5, 2008 | 12:56 PM
cowboyup's Avatar
I guess my question is if I'm run someone from a 2nd 50mph roll, will there be a difference? I dont track race, i just have the occassional run on the freeway..
Old Nov 5, 2008 | 02:49 PM
jjordan's Avatar
Well, I never had anybody ask it that way. I build lightweight aluminum wheels for racing, people tell me all the time that they can feel the difference when they switch from a heavy cast/OEM type wheel (usually around .2 in the qtr mile), so yes I would bet that you could feel it.
Old Nov 5, 2008 | 06:28 PM
SJM Manufacturing Inc's Avatar
Depending on your senses, it can be felt. Braking distances will be longer, slower acceleration, suspension reaction etc. all will change. This is why when I discuss for example our drag wheels comparing a 16lb wheel to a 10lb wheel is quite large. The center of mass is different as well with larger diameter wheels...this will show an impact on performance.
Old Nov 16, 2008 | 09:08 AM
lemons12's Avatar
well, if it is a taller tire will it not help him as far as roll racing goes..
shorter tire, quicker car(better e/ts less mph)
taller tire, faster car(worse e/ts better mph)
so if it is taller than what you have now, even if heavier, it should offset...
hope that helped... if im wrong, someone correct me please!
