factory c5 wheels
Old Nov 11, 2008 | 03:52 PM
Bishimus's Avatar
Default factory c5 wheels
Easy question for you all I hope. Will the factory c5 wheels (17x9.5 18x10.5) fit on my 02 SS?? If so I was going to get 275or55/40/17 and 295/35/18 BFGoodrich g-Force T/A KDW-2. Answers, thoughts, or opinions please.
Old Nov 11, 2008 | 04:38 PM
1badchicken's Avatar
Yes they will bolt right up no issues but why are you running a 55 side wall on the fronts. That will not look good at all. But I would double check the 10.5 wheel. They where 18x9.5 for thin spokes.
Old Nov 11, 2008 | 06:55 PM
Bishimus's Avatar
thanks, but no that's not a 55 sidewall...I meant 255/40/17 the reason for the 255 is because the tire I want doesn't come in 275.... also will I run into any problems running staggered wheels?
Old Nov 11, 2008 | 07:28 PM
dpw41285's Avatar
they are bad ***, delete that link so no one buys the though is that a sponsor site?
Old Nov 11, 2008 | 07:42 PM
rusnrno's Avatar
They will fit. I've got C5s on my Formula. They are the older style though. The off set brings the wheel inward on the car though. I had to do a slight "hammer mod" to the inner fenderwells in the rear due to rubbing on sharp turns.
I'd like to get some spacers, 5/16" or so for mine.
Old Nov 11, 2008 | 08:10 PM
Bishimus's Avatar
Ok, so I will need spacers on all 4? Also are 5/16 the size you recommend for spacers. Sorry i'm a newb at this
