tire sizes
Old Nov 20, 2008 | 10:08 PM
camaroracer91's Avatar
Default tire sizes
I run 17x 40 x 255 can I fit 245's or 265's on there or do they have to be 255's
Old Nov 20, 2008 | 10:41 PM
Texas 02 Z28's Avatar
What wheels are these?... For sure, you'll want a different aspect ratio, your tires are almost a full inch smaller than stock (275/40-17).
How wide they can be depends on how wide the wheels are. If they're 17x8's, then 255's are stuffing them nicely, but you'll want 255/45-17, or 245/45-17 would be perfect for your speedo n stuff. Orrrr, if they're 17x9.5's (stock SS wheel size), then those 255's are pretty small. You can go up to 285 I think. For sure 275 would fill it perfectly.
If you look on the inside of your wheel, on one of the spokes, it should say what size the wheel is, or you could post a picture and someone might know from looking at it.
Old Nov 20, 2008 | 11:56 PM
ae13291's Avatar
if u have 17X9 u can have 265,275,285 mayyybe a 295
Old Nov 21, 2008 | 06:29 AM
THere not stock rims and I wasnt thinking when I got them, heres a link to them
http://superbuytires.com/Velocity/Ty...1=&p2=&finish=
Old Nov 21, 2008 | 09:41 PM
17x7's, jeez. Those 255's are stuffed on there.
Here's the recommended tire/wheel width combos from the Wheel/tire section sticky:
7.0" ..... +35 to +40 mm .... 215, 225, 235
7.5" ..... +35 to +45 mm .... 215, 225, 235
8.0" ..... +38 to +55 mm .... 225, 235, 245
8.5" ..... +38 to +45 mm .... 235, 245, 255
9.0" ..... +38 to +56 mm .... 255, 265, 275
9.5" ..... +38 to +56 mm .... 255, 265, 275, 285
10.0" ... +38 to +48 mm .... 265, 275, 285
http://www.discounttiredirect.com/di...foTireMath.jsp
When you get new wheels, you have to play with the aspect ratio (middle number) to get the sidewall the right size so the overall tire diameter is the same as stock (about 26"). The stock size for a 02 z28 is 245/50-16, so you can compare sizes.
I would say look at 235/45-17's (link) as your next tires. Any skinnier and it'll probably look funny, lol.
Or you could look into some new wheels so you can throw on some wider tires. There's not a better time to buy wheels than when you need new tires (that was my excuse at least, lol). I bet those chrome wheels are heavy as **** too. Rotational mass is the #1 killer of power.
Good luck with whatever you do dude.
Old Nov 22, 2008 | 02:08 AM
kornboy's Avatar
buy the biggest and at worst, hammer the **** out of wheel well !!!!!!!!!!
