Widest tires without problems?
Old Nov 27, 2008 | 08:55 PM
photoman9988's Avatar
Default Widest tires without problems?
What are the widest front and rear tires I can fit on a '99 T/A that hasn't been lowered or anything, but won't rub or need spacers or anything? Same goes for wheels. What are the widest front and rear wheels i can run w/o and problems or spacers?
Old Nov 27, 2008 | 10:20 PM
VinR1's Avatar
search foo
several guys running 17x11's on all four corners with 315's
few have put 335's on the rear with BFH and rolled fenders
Old Nov 27, 2008 | 11:17 PM
twitchtwice's Avatar
i have the oem corvette rims, and i just had to hit a little 2" by 2" section on the inner fender in the rear and it no longer rubs.
Old Nov 28, 2008 | 12:34 AM
ALLMOTOR346CI's Avatar
Im running 315's in the rear (17x11) with no problems at all i dont think you should have a problem unless you go to a 335 then i would say break out the hammer.....
Old Nov 28, 2008 | 12:37 PM
Xsta Z 28's Avatar
Depends on way too many variables . . . not just tires, but the wheel and it's measurements.
One could runa 245/45R17 on a 8" wide wheel, and depending on the offset it will rub . . .
Or a 315/35ZR11 on a 11" wheel may fit like a glove . . .
