My Custom Set Of Torque Thrust II
Old Jul 17, 2010 | 03:56 PM
  #101
formula vincent's Avatar
those look so bad *** .. im thinking of getting a pair like those for the rear of my 94
formula ..only with the centers in black or gunmetal powdercoat. my car is bright red.
Old Jul 17, 2010 | 04:01 PM
  #102
must you torture us ?...lol ..nice.
Old Aug 14, 2010 | 03:57 PM
  #103
Default torq thrust
look in photo gallery at my black pair of torq thrust 2s
Old Dec 16, 2010 | 10:42 PM
  #104
01SOMSS!'s Avatar
Originally Posted by Gordo78
You aren't going to be able to get a lip bigger than the standard 17x11's and tuck them within the fenders without a narrowed rear....... Page two shows his custom wheels on a standard length rear, and as you can see, they stick out probably 2" on either side. I'm not sure what exactly you're asking otherwise.
i know they have a big lip but the off set is 17x11 why do they stick out so much if they are 17x11's?is it the lip? I has 17x11 with 315's and didnt stick out like that. what all needs to be done to narrow a rear end?I really want to do this to my car.thanks guys and sorry I dont know much about this dept
Old Dec 16, 2010 | 11:10 PM
  #105
hitmanws6's Avatar
Your wheels aren't custom. The lip is different on his wheels because he has a narrowed rear, the bigger lip is there to accommodate for how much he narrowed the rear. That's why when he put it on his stock rearend they stuck out a lot. And to narrow your rear you have to use shorter axle tubes/axles, the amount is up to you. So unless you can narrow your rear the 17x11 TT2 lip is all you can have to work with.
Old Dec 17, 2010 | 04:36 AM
  #106
69_YENKO's Avatar
17x11 is not the offset, 17x11 is the the Diameter vs. Width of the wheel. It is the back spacing(offset as you call it) of the wheel that effects the wheels placement in the wheel well. backspacing is the measurement from the inside edge of the wheel to the mounting flange of the wheel. It is possible to have the same 17x11 wheel with numerous different backspacing combinations, yours don't stick out because they were ordered correctly according to to the factory width rearend that is in your car.
For example: I have 15x10 bogarts for the rear of my SS. to make a 15x10" wide wheel fit correctly with a factory width rearend on our cars you need a wheel with 7.5" of back spacing. I decided that I wanted a "deeper dish" so I ordered a MWC fab9 rearend that had been narrowed 3" per side, thus giving me the opportunity of 3" of extra dish to the wheel vs the standard setup.
When I ordered wheels I now had to order a 15X10" wheel that had a 4.5" backspacing, since the rearend is narrowed 3" this put the outer edge of the wheel in the same location a stock but gave me TONS of extra dish.
If I were to put a the standard 7.5" BS wheel on the rear of my car now it would sit inboard 3" and look ridicules, on the same note if I was to put my custom 4.5" BS wheels on the back of a factory width F-body they would not have enough BS and would stick out 3" past the quarter panel and look like something you might see driving through the barrio.
Hope this helps you put it into perspective.
Old Dec 17, 2010 | 10:02 AM
  #107
SmokedOutZ28's Avatar
The best time to narrow your rear end is when you replace it with a aftermarket unit. It's no extra cost and will be done correctly.
Old Dec 21, 2010 | 07:18 PM
  #108
Fast T's Avatar
Bro those look super bad ***. I love the way they look on your Z.
Old Mar 2, 2011 | 10:56 AM
  #109
blown99bergerssclone's Avatar
I just bought a rear yesterday and suppose to be 2" per side . Do you have the flange to flange measurement from your rear So I can double check mine and if mine is 2 what offset should I order with the 12" wide wheel? What is the widest tire that will work with bfh/bumpstop/rolled fenders?I appreciate your help. Thanks
Originally Posted by SmokedOutZ28
Update!!! The long back order wait is over!
Got the front wheels and put them on, Here are some quick driveway shots. The Front wheels are 17x9.5 and the rear wheels are 17x12 with a 5'' backspacing. All polished with chrome barrels.
Old Mar 2, 2011 | 11:32 AM
  #110
*02WS6TURK*'s Avatar
Them are deep alright Looks good!
Old Mar 2, 2011 | 09:18 PM
  #111
I have the measurements laying around in the garage I believe. Your wheel / Tire combo is going to be dependant on you.
I would install the rear end and then measure how you want the wheels to fit & sit. I did it the oppsite and had to order another set because I didn't like how the wheels sat in the fender.
The rule has been 2'' off each side of the rear end means 2'' off the stock backspacing but that run didn't work for me and my wheels were tucked too much for my liking. I ended up with a backspacing for a rear end cut almost 3'' on each side to have my wheels sit with no rubbing issues and no clearance issues.
Old Mar 2, 2011 | 09:29 PM
  #112
17x11 with 5.75 backspacing since my rear was cut 2'' each side. (didn't like how they tucked)
So I measured instead of following the rule and these sit to more of my liking and are 1'' wider then the previous set. No spacers, No tricks Just ordered another set of wheels with different offset
Old Mar 2, 2011 | 11:23 PM
  #113
Very nice what bs did u end up with and if you could get the rear specs I'd appreciate it. Thanks
Old Mar 28, 2011 | 08:36 AM
  #114
Fryguy302's Avatar
So TOMZWHEELS is apparently out of business now.
Any recommendations for a place to order custom wheels like this?
Also, has anyone tried to get a very narrow set of front TT2 wheels, like 17x4?
Thx.
Old Mar 28, 2011 | 08:43 AM
  #115
Summit Racing can order them. You could also try discount tire or any American Racing supplier.
Old Mar 28, 2011 | 10:33 PM
  #116
98sscammed's Avatar
Like it
Old Mar 29, 2011 | 09:14 AM
  #117
SouthTexasBully's Avatar
Nice....
Old Mar 29, 2011 | 09:21 AM
  #118
TransWS6Am's Avatar
i'v got the link for the cheapest i found, i got my 17x11 Torq Thrust II with 5.5 backspacing/5.5 inch lip for $620 they came with lugnuts and valve stems. PM me for the link.
