Front runner tires, which ones?
Old Dec 21, 2008 | 09:04 PM
DopdBrd's Avatar
Default Front runner tires, which ones?
Ok so I am looking to get some front runners for now, I'll just keep the 17" Fikse's until I decide what rears to get.
Now, I know you are not supposed to mix Bias Ply and radials on the same car. But what I want to do is EVENTUALLY run some 28x11.50 ET Street rears. If I do that, I need to run some Sportsman fronts.
But if I get some Sportsman fronts, would it be alright to OCCASIONALLY run the 15x3.5's with some Sportsman fronts while I keep my Fikses with 295/45R17's ET Street Radials on the rear?
Old Dec 22, 2008 | 12:17 AM
SJM Manufacturing Inc's Avatar
Sure, you can do that, though handling and braking will be terrible if you're planning to use this as a street setup.
Good luck with your setup.
Old Dec 22, 2008 | 09:23 AM
DopdBrd's Avatar
Thanks. I won't be running them all the time. Rarely on the street and mostly on the track, I just want to be able to run them OCCASIONALLY on the track.
Thanks for the input.
Old Dec 22, 2008 | 11:56 AM
Your welcome.
