Do wider tires hook better?
Old Dec 28, 2008 | 10:50 PM
Raptor_WS6's Avatar
thx for some of that info guys, i want to run a taller tire on my t/a.. currentloy running 315/35/17, does anyone know who makes a taller drag radial.. like 315/40... 325/40... or something like that
Old Dec 29, 2008 | 09:05 AM
03_r6's Avatar
M&H makes a 325/45R17 i think people have had good results with but i can't speak from experience. here is a link http://www.mandhtires.com/store.php?...on=show_detail also Hoosier makes a 335/35R17 that i believe 'Trust' is running or has ran in the past.
Now, not to belabor the point but FRICTION has nothing to do with traction, acceleration, or anything really in this application. Tire pressure is lowered so that sidewall deformation (flex) can occur and somtimes set down a little larger footprint (not friction, remember friction is independent of surface area so that would be ADHESION). When you have a sticky tire sidewall flex can take some of the abuse off the rear end and the energy is not lost, just stored in the sidewall and released when the tire returns to it's "original shape". You will notice a better 60' but tend to sacrifice some on the big end of the track. This is because the whole time you go down the track the tire is under inflated and takes more energy to cause angular acceleration (speed up) If you have two identical cars with one has a DR inflated to street spec and one is on track tire pressure and they "race" from a roll () the car with the higher psi will win because there is no energy lost in the sidewall of the tire being under inflated. It takes energy for the under inflated tires sidewall to continually change shape as it goes down the road this just means less power being translated to making you accelerate. This same concept can be applied to gas millage. Take two identical cars have one inflate their tires to 25psi and one to 35 psi and go on a road trip, the car with 35psi will get better gas millage. So as you can see friction is erroneous in this application.
Cliff Notes: Afro is right but for the wrong reason, higher psi is better acceleration, but lower psi tends to yield a better launch
Old Dec 29, 2008 | 11:20 AM
Blevinator's Avatar
So, what is the WIDEST 17 with the MOST flex I can use without modifying my stock height T\A vert? Tire size please. NOT wanting to hammer fenderwell.
Thanks!
Old Dec 29, 2008 | 12:05 PM
drewwrxrogers's Avatar
^I am getting close to selling my 11.5 ZR1's I have in the shed for track days. I used them with a 315 radial to hook but they honestly are much heavier and more mass than my daily driven 9.5 z06s with et streets. I think I just need to run em both at the track to see side by side results because I have always just kinda assumed the nearly 4 inch wider path my 11.5 315 combo was making was better at the track...hmm gets me thinking what I could buy if i sold them....haha.....They do look straight sick as **** though wooooh.
Old Dec 29, 2008 | 12:09 PM
streetassasin's Avatar
Those run narrow, they are roughly the same width as a bfg 275-285 You might want to run the m&h 390/40/17 but it is a BIG tire 29.5", shouldnt have any traction problems with them
Old Dec 29, 2008 | 01:23 PM
03_r6's Avatar
haha i was unaware that M&H ran narrow but 390/40 sounds like one hell of a tire!
Old Dec 29, 2008 | 01:27 PM
https://ls1tech.com/forums/wheels-ti...0-40-17-a.html
Old Dec 29, 2008 | 06:19 PM
DopdBrd's Avatar
I ran 325/45R17 M&H Drag Radials on my 17x9.5 Fikse's and they worked GREAT. Damn things bogged the car off the line with a 3500 RPM launch. I fed it more RPM the next launch and my clutch hydraulics went bye bye.
