Stock offset?
Old Oct 9, 2003 | 08:47 PM
TravWS6's Avatar
Default Stock offset?
well i finally found the perfect wheels for my car.. the ROH RT's.. im gona get the 17's so i can save big time money from 18's and the pricy rubber.. but anyways my question is wuts the offset on the stock 01 WS6 wheels.. there 17's.. cuz i think these ROH's are 0 offset.. so wut exaclty does that mean? there gona be completly in the wheel well?? i want them to stick out a bit.. as long as they don't rub the outer fender.. gona be running stock tire's anyhow.. 275/40/17 thanx guys
Old Oct 10, 2003 | 08:16 AM
Xsta Z 28's Avatar
Default Re: Stock offset?
Offset on stcok wheels is a negative 50 mm. The lowest one can go with an F-Body is 38 mm.
Bascially a 0 offset wheel is the mounting surface of the wheel is flush with the centerline of the wheel. And on a F-Body they will stick out BIG TIME!
Old Oct 10, 2003 | 08:25 PM
TravWS6's Avatar
o ok.. i understand.. the center of the rim.. dam ya that would really stick out far..
