valve stem hole size
Old Feb 10, 2009 | 12:12 AM
jetlag's Avatar
Default valve stem hole size
What is the valve stem hole size in ZR1 replicas?
I need to get some bolt-in valve stems and not sure what size to get.
On Summit it has these options,
* 7/16 in.,
* 5/8 in.,
* 5/16 in.
I think I'd guess 5/16??? but not sure..
Old Feb 10, 2009 | 05:33 PM
SJM Manufacturing Inc's Avatar
7/16 is typical. If you're running tubes, 5/8's
We have them in stock if you need them. They are 3.25 each.
The ones we use work for both applications.
Old Feb 11, 2009 | 12:07 AM
jetlag's Avatar
I'll be using Mickey Thompson drag radials.
Steve, I'll be calling soon to order that ABS delete kit, so I'll have to add some of those to my order... Thanks
Old Feb 11, 2009 | 01:08 PM
You're welcome. Let me know if you need anything in the meantime.
