Lowering with 20's?
Old Feb 10, 2009 | 05:49 PM
slvr20cam's Avatar
Default Lowering with 20's?
Have 20"s on now and just bought Eibach Pro Kit..will I have enough clearence...dont want them to rub. Anybody have this setup?
Old Feb 10, 2009 | 05:57 PM
96BIGBODY's Avatar
How wide are the wheels and tires?
Old Feb 10, 2009 | 06:07 PM
slvr20cam's Avatar
Old Feb 10, 2009 | 07:16 PM
TheLSgun's Avatar
depending on the offset you should be fine.
Old Feb 10, 2009 | 07:26 PM
johnLs1camaro's Avatar
got any pics? does that kit only lower it about a inch?
Old Feb 10, 2009 | 07:47 PM
slvr20cam's Avatar
It says it lowers 1.5" i got almost 2" in the front and 2.25" in the rear to play with before tire...it should clear..Im just worried about rubbing when i hit bumps
Old Feb 10, 2009 | 07:49 PM
slvr20cam's Avatar
they say 1.5"
Attached Thumbnails Lowering with 20's?-jnjfd.jpg   Lowering with 20's?-p1010010.jpg
idk you should be ok, the rims arent that wide your putting on and tires size should be ok.
Old Feb 10, 2009 | 08:07 PM
Wing Zer0's Avatar
I have the same size rims and tires. I Don't know what the offset is of my rims. I am riding on Sportlines though. Hope this helps.
Old Feb 10, 2009 | 08:17 PM
Cobra2WS6's Avatar
Can u post some pics
Old Feb 10, 2009 | 08:22 PM
slvr20cam's Avatar
I did above unless you wantof the whole rim..i have to dig through some mem cards to see if i have any because i dont have my camera with me.
Old Feb 23, 2009 | 03:45 PM
outtacontrolz28's Avatar
I have a 18/20 combo and have no issues with clearence. 285/35/20 rear 245/40/18 front
Old Feb 23, 2009 | 03:47 PM
Detoxx03's Avatar
That looks good.
To the OP if you rub just roll the fenders a little
Old Feb 23, 2009 | 08:22 PM
00FlowCamaro's Avatar
Wow, those Z06's look reeaal good on there, nice choice.
Old Feb 23, 2009 | 08:34 PM
99Bluz28's Avatar
Question
Those sure look more like 285/30/20 to me, because a 285/35 would have a sidewall at least as tall as a 245/40, plus a 285/35/20 would be around 27.85" tall.
Old Feb 23, 2009 | 09:34 PM
Silver UltraZ's Avatar
Im running 285 30 20 all the way around
Old Feb 23, 2009 | 10:43 PM
fordeater's Avatar
a 255/35/20 is 27.0" tall...you should be good depending on the BS of the rim, the pro-kit is not a crazy drop.
Old Feb 24, 2009 | 05:24 AM
They might be..I havent seen my car in about 3 months. You might be right though. I will confirm it tomorrow when I pick up the car. Since i will be selling them here in the next week.
