How big can i go
Old Feb 16, 2009 | 04:22 PM
paul12001's Avatar
Default How big can i go
Got sum 19x10 for the rear and 18x8.5 how big of tire can i go with these on my 96 z i have 1.25 spacers for these
Old Feb 17, 2009 | 11:29 AM
paul12001's Avatar
can i fit 295s on the rears?? also which is better BFGoodrich g-Force T/A KDW 2 or NItto 555?
Old Feb 17, 2009 | 12:11 PM
1BadTA13's Avatar
not sure if it will fit, but i know nitto's usually run small.
Old Feb 17, 2009 | 12:19 PM
dondb's Avatar
Actually i just bought a pair of Nitto 305/35/18.... 305MM should = 12" they measured 12.4" so they were running big?
Old Feb 17, 2009 | 01:34 PM
paul12001's Avatar
well whats the biggest i can put on a 10inch rim?
Old Feb 17, 2009 | 01:50 PM
dondb's Avatar
The Nitto specs say the 305 DRs will go on a 10" rim....but i ended up sending them back and getting the new NT05s 295/35/18's. To keep the DRs with my 10x18's with 54mm offset, i was going to have to use BFH mode, and i didn't want to do that. I have a 295/35/18 Michelin on there now measuring 11.7 with very slight rub, the NT05's measure 11.6 tire section.
So bottom line... the 305 DR's will fit depending on your offset and possible willingness to do the BFH mode.
Old Feb 17, 2009 | 03:54 PM
homerunhtr21's Avatar
https://ls1tech.com/forums/wheels-ti...must-read.html ....all your info is there
