Weight of Bogart wheels?
Depending on the application (LT1, LS1) The BS VERY similar to the welds rears shy under 7.5. The lugs needed are shorter by about 3/8" of an inch (LS1) (5/8" LT1). They also don't use the large washers welds lugs have...they require the smaller style washers like SST, McGard etc uses.
:-) Steve
not sure on the backspacing, and the weld lug nuts will work, the fronts need a smaller washer, but thats all.
Steve
On thursday i'm going to have my 26x10 hoosiers put on my bogart rears (15x10) and you can see how light they are
i also have 15x4 fronts with 28" ET Fronts
