drag rims ?'s
Old Mar 6, 2009 | 09:46 PM
srider's Avatar
Originally Posted by evil8
What are these called? I think if these could be had in a 3.5 with 1.25 backspacing, the might fit the ls1 cars.
The S197 GT fitment and LS1 are nearly identical. They will fit LS1's also.
Old Mar 6, 2009 | 09:48 PM
ZMONSTER!'s Avatar
Oh boy a sponsor pissing contest! Yippee!
Im going with summit.
Someone delete this?
Old Mar 6, 2009 | 10:07 PM
SJM Manufacturing Inc's Avatar
zmonster. Its not a pissing contest at all. Though the summit wheels are not USA made, it's an economical choice which is very hard to not consider. I recommend them to many often. Our or other billet series wheels are not in every persons budget or goal...there are always other options.
Dragwheelz, our hoops can split. Never stated they didn't or won't. I've stated our failure rates I've seen. Our material is actually thicker than what is being used by those "street" wheels. Now that you mention it, maybe our customers were using lighter fluid to seat the tires...thus why they failed.
I find it funny how you blast our drag wheel stating they are so much weaker. We do not use the manufactured hoops BS is using for our drag wheels. Our street/strip wheels, we have used in the past probably the same manufacture that Billet Specialties use for their hoops (2 piece design) ...thus why in the past I've told you and others why our street/strip wheels are no different...go figure, you kept pushing yours were "so different". We have had customers with similar failures.
Now using those front radials as you setup on those "street configurations"...I think you're going to find things are not what you assumed at the beginning. I've been in the business for many years.
Our difference of wheels lies drastically with the application they are used for. Billet specialties is a stated "street" wheel with "SFI" touted ratings which are to be in your terms street rated (not so)....anyways.
Regarding in-house results. I'd be curious as an Engineer as to what they "find" out.
...srider is correct about welds fitment. The backspace is rather small so they may look funny to some something to consider.
Old Mar 7, 2009 | 09:56 AM
Camaro396's Avatar
Steve, just curious what you mean by the backspace is rather small? Do you mean because there is not much of a dish?
Old Mar 7, 2009 | 10:15 AM
It was stated previously the backspace was 1.25" which is small. As you know, the wheel will stick out of the fender well quite a bit. Anything less than 1.75" doesn't fit under the fender well nicely. It also encroaches on the actual plastic fender lip and becoming interference issue.
If you can get a set on the car, take a few pictures, I'm sure there are some members on here that would love to see how they look. There's a friendly Weld rep who frequents here...maybe he can chime in and clarify the backspace options for the fronts. I'm only going by what a previous poster stated on this post.
Old Mar 7, 2009 | 10:21 AM
Camaro396's Avatar
Oh, that makes sence. I for some reason thought you were talking about the rears. I'm still half asleep.
Old Mar 11, 2009 | 09:05 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
According to Jegs, the front Welds weigh in at 10 lbs and the rears at 15
Old Mar 11, 2009 | 04:13 PM
Camaro396's Avatar
Yes they do!
