how much backspacing?
Old Apr 3, 2009 | 12:37 PM
02yellowls1's Avatar
Default how much backspacing?
im ordering some jegs sport stars wheels (weld prostar look alikes) and im planning on getting 15x4 for the front and 15x10 for the rear. what backspacing should i get for the rears i got options of 4.5, 5.5, or 6.5. i dont see a option for the front do they need backspacing also?
Old Apr 3, 2009 | 02:49 PM
Camaro396's Avatar
Fronts should be 1.75" backspace. For a 15x10 to correctly fit a 4th gen F body you need 7.5" backspace, which they don't offer in the Jegs/Summit brand wheels.
Old Apr 3, 2009 | 04:22 PM
bjamick's Avatar
Yep 7.5 is whats needed. If you go to 5.5 BS you have to narrow the rear end.
Old Apr 24, 2009 | 02:42 PM
black01_WS6's Avatar
how far out would the tires be with a 15x10 with a 6.5 bs? does anyone have any pics? Do I need a large spacer, or can't fit a larger tire in the future?
Old Apr 24, 2009 | 02:56 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
You can run a 15x4 with 2.25 back spacing
