Help with Prostars
Old Oct 26, 2003 | 11:45 PM
BadCompanySS's Avatar
Philly Fakeout!
Default Help with Pro Stars
I'm wanting to put some 15" Weld Prostars on my 2001 SS. What backspacing and sizes will I need to get? Am I going to need spacers and longer studs? Any help would be appreciated.
Thanks!
Oh yeah, if anyone has a picture of Prostars on a red camaro I would really appreciate it.
Old Oct 26, 2003 | 11:48 PM
NiceTry's Avatar
for the rears i depends on what size you need.for a 10 inch wide wheel i'd probable go with a 7.5 inch back spacing and for a 8 inch wheel i'd go with a 5.5 inch backspacing. for the fronts i'd go 15X3.5 that way you won't have to grind very much on the caliper.
Old Oct 26, 2003 | 11:53 PM
BIGBOS's Avatar
I run 15x10's in the back with 7.5" backspacing, and 15x3.5's in the front, I run extended studs in the back, thats because my car is fairly fast, running a 5/16th's spacer, LOTS of grinding involved with the calipers in the rear to make it fit, none in the front w/the spacer...
Old Oct 27, 2003 | 10:34 AM
NOTFAST's Avatar
can you use a 5/16" space on the rear with the 15x8 (5.5" bs) to prevent grinding?
Old Oct 27, 2003 | 10:57 AM
NiceTry's Avatar
i'm not sure to tell you the truth. i don't care for spacers very much, more of a chance for the wheel to come off. i won't even work on cars with spacers for liability reasons.
Old Oct 27, 2003 | 04:08 PM
Philly Fakeout!
Prostars or Centerline Telstars?
Old Oct 29, 2003 | 05:50 PM
Philly Fakeout!
Wont the lugnuts go through the wheel? Don't really understand why you need longer studs.
Old Oct 29, 2003 | 05:56 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I have 15x10 Pro Stars in back, no spacers, a lot of grinding. 7.5 backspacing.
Old Oct 29, 2003 | 11:54 PM
CAT3's Avatar
Restricted User
NHRA rules require the longer studs....the stud must be nside the hex portion not less then the width of hex deep, or some crazy size. The load is not very well distributed without longer studs.
BIGBOS...what stud you run up front? When I mount my skinnies, 15x3 or 4, I have a hard time getting the lugs started since the ARP stud sits even with the hub using a 3/16th spacer! I need a longer long stud!
Old Oct 30, 2003 | 05:10 PM
1F8TL02WS6's Avatar
how big of a spacer to make the 15x10 fit??? I wanna do the least amount of grinding one mine. Im about to order a set aswell here soon.
Old Oct 30, 2003 | 05:11 PM
LS1Tech Co-Founder
5/16 spacer 1fatalpontiacguy.
Old Oct 30, 2003 | 06:00 PM
1F8TL02WS6's Avatar
hahaha thanks man I guess I kinda over looked that earlier.
Old Oct 31, 2003 | 11:25 AM
MIGHTYMOUSE's Avatar
15*8 with 5.5bs or 15*10 with 7.5 bs... both have a 2.5" offset and will require the same amount of grinding.. i reccomend using 5/16 spacer for each.
if you are running fast enough to need longer studs.. then you COULD use a thicker spacer and not grind at all.. but i dont reccomend that.
some people dont have to grind the fronts at all with a 5/15 spacer on a 15*3.5
centerlines have less backspacing (more offset) and will not be flush with the fender.. if you like that look, they don't need grinding..
this is how a car looks with 2.5" offset wheels and 5/16 spacers. (my car)
http://community.webshots.com/photo/...74309555yhfgbT
Old Nov 1, 2003 | 08:09 PM
pla-tym's Avatar
Hey, BadCo01ss,
Yesterday I put on 15x3.5 pro stars (front) 5/16 spacer (clears calipers by .125) 165/15 tires. Lugs have plenty of thread, Works very well.
BTW pro star 10lbs ea.
17x9 25lbs ea. ( less rotational weight)
