Is this tire still OK or junk??
Old Apr 18, 2009 | 07:28 PM
hyundaiboy's Avatar
Default Is this tire still OK or junk??
I had this tire on the rear of my camaro. It still has 70% tread left. The only reason it was taken off is because the other rear tire was damaged beyond repair.(A utility knife blade was found inside). So I ended up putting 2 new slightly wider tires on. The tire looks perfectly fine on the inside. Is this still ok or not?
Old Apr 18, 2009 | 08:29 PM
hitmanws6's Avatar
where is the puncture?
Old Apr 18, 2009 | 08:53 PM
hyundaiboy's Avatar
Old Apr 18, 2009 | 09:19 PM
hitmanws6's Avatar
as long as there is no leak you should be fine. you can get it patched if you would like
