Problems with Goodyear!
Old May 5, 2009 | 12:54 PM
chevygirl's Avatar
I know alot of things should have been done. The shop doesn't like Goodyear. It stopped moving but the balance won't stay at all. The new tire is suppose to be here today and I am going to a Goodyear shop to have it mounted up so hopefully no more issues. I got tired of dealing with going to the other place every 3 days or so. I lost 20 hours of pay at work over it.
Old May 5, 2009 | 06:20 PM
leadfoot4's Avatar
I understand your frustrations....But, you skipped over my initial question. Did you have another tire previously on this wheel? If so, was it OK?
Old May 6, 2009 | 03:44 PM
zymox's Avatar
When you get the new tire, and if it slips on the wheel, then have them switch the tires and wheels. They should know this and should have already done this anyway. Mark the wheels so they don't get confused.
I'm a wheel manufacturer by the way. OE Concepts. Not likely to have a wheel out of spec like that.
Old May 6, 2009 | 10:28 PM
SS SLP2's Avatar
just thinking, problem may be too much mounting lube on a slick wheel, may ask installer to wash the rim and hold the mounting lube
Johnny
Old May 6, 2009 | 10:56 PM
hitmanws6's Avatar
^^^ the lube they use is ok for Z rated tires, but to be sure have them use soap and water
Old May 7, 2009 | 03:59 PM
chevygirl's Avatar
These are stock GM SLP wheels that are 9 years old with no prior problems. I don't think they know how to use the road force machines at the places I went. It is only one tire that has moved and it did not continue to move but it won't stay balanced. I ended up with 8 ozs of weights. I don't think they know what they are doing. Nice machine aren't any good if you don't know how to use them.
Old May 10, 2009 | 08:31 AM
ChoiceCam00's Avatar
Default Question
So you say that now the tire doesn't move on the wheel but your balance is off a little. Did you hit a curb to knock your alignment off? I know that these are OEM but, maybe you need one hubring to center the wheel on your hub and DT can help you with that. Usually this is only for after market wheels like my AR 699 Rebels 18". I have had problems with Ted Weins(Goodyear Dealer) here in LV but I've never own a Goodyear tire due to personal preference on BF Goodrich and have used Discount Tire since 1990 here in Las Vegas. Good luck!
Old May 10, 2009 | 10:57 AM
chevygirl's Avatar
****5/9/09 Update New tire installed Thanks to Discount Tire Direct and Matt- Came out only needed 2.5 ozs instead of 6 ozs like the old tire. The tire did not move on the wheel like the old tire- vibration is alot better than it was****
Old May 10, 2009 | 05:13 PM
ben77's Avatar
sweet, glad it worked out!
Old May 10, 2009 | 05:56 PM
leadfoot4's Avatar
Good to hear.........
However, as "ChoiceCam" mentioned, you may want to check the alignment, just to be on the safe side.
Old May 11, 2009 | 09:54 AM
Discount Tire's Avatar
That's awesome! I'm glad your tire issue is finally resolved Let me know if you have any trouble sending the old tire back. If you can, PM me the tracking number so I can keep an eye on it.
Thanks!
Old May 11, 2009 | 10:32 PM
  #32
chevygirl's Avatar
I sent you a pm tonight and I will send you the tracking number as well. I am very thankful to you more than you will know that you took the time to help me out.
Old May 12, 2009 | 10:43 AM
  #33
TheSilverOne's Avatar
DTD banned? damn.......
Old May 12, 2009 | 01:08 PM
  #34
Danny2tek's Avatar
Guess you cant be giving out free customer service
