Skinnys?
Old May 4, 2009 | 12:19 PM
Lopoetve's Avatar
Originally Posted by Camaro396
Are you serious? It makes all sorts of sence. You go a lot faster. Wheel weight is more importaint than any weight. Each static pound is three pounds when converted to rotating mass.
I wasn't thinking about drag racing - I was half asleep and just thinking about cornering and handling, not straight line :p
Old May 4, 2009 | 12:53 PM
Randy WS6's Avatar
I drive mine on the street all the time ,and cant even tell any difference in the braking or handling, and plus the back brakes help stop to in case of a sudden stop.
Old May 5, 2009 | 06:40 AM
airforcemanss's Avatar
for you guys driving around on the street with these drag set ups on radial tires, is it safe? i heard if your on the highway doing a 100+ you start to get a little bouncy which doesn't sound safe too me. am i better off going with a bigger rim 17" an doing a 315 for a tire or are the 15" with more tire fine w/
15x4 up front? i don't have enough money for drag/strip so that's outta the question.
Old May 5, 2009 | 09:57 AM
Camaro396's Avatar
I've never had an issue.
Old May 5, 2009 | 11:27 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
