Question about road comfort
Old May 10, 2009 | 06:59 PM
qwikz28's Avatar
Default Question about road comfort
Hey all, I am running a Strano/Koni setup in the glorious land of NY/NJ. The potholes have simply become too much to bear and I need to switch my 18" wheel setup. My buddy has the same setup with 16" wheels and it is significantly smoother. My question is this: Will a 17/18 setup solve my problem or should i opt for 17" all around? I assume the grunt of the problem (harshness on bumps of course) is from the front end, so this should solve it. Has anyone done this before or experienced similar results? Thanks
Old May 10, 2009 | 09:12 PM
ben77's Avatar
I think you need to worry more about the profile of the tire more than the size of the wheel if you're worried about comfort. I mean if you go 17" and use a tire with the same profile as your 18" wheel had, you'd prob feel almost the same amount of road harshness. Your friends 16" wheels feel better probably because his tires have a ton more sidewall than your 18" tires.
Old May 10, 2009 | 09:42 PM
99Bluz28's Avatar
What your tire pressure set at?
I try to keep mine at 32 front & 30 rear
Also try adjusting your Koni's .
Old May 11, 2009 | 10:12 AM
qwikz28's Avatar
Yeah, I granted that the 17" wheels would provide for more tire sidewall than an 18". An 18" is low profile while an 16" and 17" is not
i set my tires around 35 and i will try lowering the konis one sweep and see if that helps.
Old May 11, 2009 | 10:46 AM
99Bluz28's Avatar
Dropping the tire pressure should make a noticeable improvement. I know when I've had my tire pressure set around 35-36 psi with my 18s, the ride quality was terrible!
Old May 11, 2009 | 02:22 PM
qwikz28's Avatar
yeah i had it originally at 30, brought it up to 38, then down to 35. i could feel a difference, but it was not even close to as good as my friend's car with the smaller wheels. i think the 18s have to go. they are beautiful wheels, but it is time
Old May 11, 2009 | 02:31 PM
99Bluz28's Avatar
Lightbulb
What brand/model/ size tires you have on there now?
The reason I'm asking is that my falken 452s 18s ride very similar to my factory 16s, I can notice a slight increase in impact harshness from the 16s to the 18s , but that's it.
It could very possibly be just the brand/model of tire, not the fact they're 18s.
Old May 11, 2009 | 06:01 PM
qwikz28's Avatar
hmmm... do you mind me asking what your suspension setup is like?
Old May 11, 2009 | 08:03 PM
99Bluz28's Avatar
Front:
Edelbrock front IAS shocks with Hypercoil 600 lb.in. springs and "upper mount mod".
Global West upper control arms delum bushings in the factory control arms, UMI front LCAs, Hotchkis front sway bar.
Rear:
Edelbrock IAS shocks, GlobalWest rodend PHB, DKT LCAs with Johnny Joints.
BMR LCA relocation brackets, Factory bumpstops cut down 1", A.R.T. Coolride Air spring kit, Hotchkis rear sway bar.
Also I'm running 275/35/18s up front and 275/40/18s rear, with Falken 452 tires.
