Quick Offset Question
Old Aug 5, 2009 | 10:52 AM
ShortChevy's Avatar
Default Quick Offset Question
Hello, I just have a quick question about some wheels. I've read the sticky at the top about which offsets to use. I'm thinking about buying some stagered rims that are 8.5 +35 and 9.5 +35. The sticky says to run a min. of +38. My question is it should fit right? It would just stickout another 3mm correct. Anyone else run these offsets? Does it look goofy or something?
Old Aug 5, 2009 | 12:46 PM
Xsta Z 28's Avatar
The 8.5" wheel should be fine . . . the 9.5" wheel . . . out back should be ok . . . it is REALLY pushing it. The quarter lip will most likely need to be rolled.
Old Aug 5, 2009 | 12:50 PM
ShortChevy's Avatar
You are the man, thanks for such a quick response.
