Should I need a spacer??
Old Aug 19, 2009 | 10:56 PM
QuickSilver's Avatar
Default Should I need a spacer??
I am just trying to fit 18x9.5 C5 rears on my TA. They have a 285-35-18 tire on them. They dont seem to be fitting right should i need a spacer with this combo?? Everythihg i have read says this should fit fine.
Thanks for the help
Josh
Old Aug 19, 2009 | 11:30 PM
bulletz28's Avatar
I have 18x10.5 with 295x35x18 tires at rear and I dont have spacer, just have to roll fender
Old Aug 20, 2009 | 01:02 AM
Are they an OE C5 wheel? with the rear suspension hanging i was hitting the bump stop.
I havnt tried it yet with weight on it.
Old Aug 20, 2009 | 05:52 PM
Posi's Avatar
With an 18" wheel there should be no hitting the bumpstop and unless you have some crazy offset you shouldn't rub either. Jack up the rear axle when fitting your tires. I am betting that is why you are having issues. Once you have weight on it, the bump stop is going to sit well inside an 18" wheel.
