Prostar Help
Old Nov 24, 2003 | 02:44 PM
PlainwhiteZ28's Avatar
Default Prostar Help
Ok,
I am going to get 15x10 with 7.5 BS and a 5/16 spacer? correct
and for the front 15x3.5 with 1/4 spacer, what BS?
help me out here.
and how much grinding is really necessary?
Old Nov 24, 2003 | 03:39 PM
SilverGhost's Avatar
Motorboater
I can't remember the BS for the front rims.
a 3/16 spacer for the backs will be fine, run the smallest you can.
the backs will require a LOT of grinding, its a pretty big job to fit that rim even with a small spacer. Mine are ground to like nothing with the 3/16..
Old Nov 24, 2003 | 04:56 PM
WILWAXU's Avatar
Fronts only come in one BS for the 15x3.5", 5/16's spacer.
The rears are 15x10 BS 7.5 or 15x8 BS 5.5, both use a 5/16 spacer. Rears can be ground to use no spacer...
Old Nov 25, 2003 | 01:03 AM
BIGBOS's Avatar
I used the 5/16's on my fronts, worked fine, and a 5/16's on the rear with extended studs, since I have a pretty aggressive setup, A LOT of grinding was done, I'm running a 15x10 in the back 7.5 back spacing with a 28x12.5x15 et street, bump stop is completely ground off, had to do some pounding in the fender wall as well....
