18X10.5 wheels
Old Dec 4, 2003 | 08:49 AM
Mulari's Avatar
Default 18X10.5 wheels
Am i going to have a clearance problem or problems with rubbing on the inside of the wheel well if i go with a 18X10.5 wheel? My car is stock height and i don't plan on lowering it any. Thanks.
Old Dec 4, 2003 | 08:56 AM
2000Z28M6's Avatar
If you are referring to the rear tires only it will mostly depend on what backspacing the wheel has and also what size tire you decide to run. Your post is very unspecific, more information would be needed to answer your question properly, hence post the tire you gonna use and the wheel brand and backspacing you plan on using.
Old Dec 4, 2003 | 09:52 AM
Xsta Z 28's Avatar
Yep -depends on the actual wheel, offset and back spacing . . .
Old Dec 4, 2003 | 09:17 PM
MOTRUBL's Avatar
18x10's, 7.5 back space, I'm lowered and I don't even come close. I could have done an 18x11.
Old Dec 5, 2003 | 11:03 AM
2000Z28M6's Avatar
motrubl I thought you were selling your wheels ?
Old Dec 5, 2003 | 12:18 PM
Todd@AZPowerAndSound's Avatar
10.5" width...stay +50 to +56 front and rear and you're fine
