Will these tires work?
Old Oct 11, 2009 | 07:51 PM
photoman9988's Avatar
Default Will these tires work?
I'm about to get some 18's all the way around. I was told that the overall diameter needs to be within .5" of each other so my abs won't freak out, but I have no idea how to calculate that. Right now I have 265/35/18 and 295/30/19 and apparently, that doesnt work out. I'm going to put on 275/40/18 and 295/35/18. Are those sizes within .5" of each other?
Old Oct 11, 2009 | 08:11 PM
therealcreeper's Avatar
google "tire diameter calculator"
select first link, and then just plug in your numbers
Old Oct 11, 2009 | 09:25 PM
Hm.... The diameter of the fronts will be 26.66in. and the rears will be 26.12in.
Should that be ok?
Old Oct 11, 2009 | 09:37 PM
shaun's Avatar
you need a 275 35 18 in the front
Old Oct 11, 2009 | 09:57 PM
That makes it 25.57 in the front, which would be WORSE...
Old Oct 11, 2009 | 10:00 PM
shaun's Avatar
thats what is suposed to be on the front.
Old Oct 11, 2009 | 10:18 PM
But I was told that if there is a .5" difference in diameter, it will set off my abs like it is now with my 265/35/18 and 295/30/19 set up.
Old Oct 11, 2009 | 10:29 PM
IWGF's Avatar
I heard it was more like 2" but I don't know if there's any truth in that... You're asking the wrong guy, I cruise on bigs and littles all day.
Old Oct 11, 2009 | 11:56 PM
there's a difference between what you need, and what's supposed to be there. yes that's what it should be, but it's not the only thing that will work. i have 275/45/17's in the front and 275/40/18's in the back with absolutely no problems at all apart from the speedo being a few mph off.
Old Oct 12, 2009 | 09:52 AM
Xsta Z 28's Avatar
I run 275/35R18 and a 295/35R18 and have no issues.
Old Oct 12, 2009 | 08:46 PM
Posi's Avatar
Same here.....
Fronts: 275/40/ZR17 (25.66 inch diameter)
Rears: 305/35/ZR18 (26.40 inch diameter)
So that's almost an inch difference and had no problems with the ABS or TCS. I then used a diablosport predator to set tire size to recalibrate the speedometer and still didn't have a problem.
