Rims.
Old Oct 30, 2009 | 03:11 AM
Mr.z/28's Avatar
Final Question. On the 4th pic of the black z28, what is that tire size? would it be 15x3.5 or 4 or 5?
Old Oct 30, 2009 | 03:37 AM
1killerSS00's Avatar
Originally Posted by Donohue96M6Z28
The first set at first glance looked like weld prostars, but I think they have bogart center caps. Not sure what model though...
The second set are weld draglites...
What kind of rims and tires are on your car. very nice looking. do you know where i can get a pair of them? both rims and rubber. and how much it would be.
looks sweet!
Old Oct 30, 2009 | 04:20 AM
Mr.z/28's Avatar
looks sweet!
youll laugh. those are stock z28 rims.
Old Oct 30, 2009 | 04:23 AM
Mr.z/28's Avatar
Are these it?
http://www.performanceplustire.com/p...250#prodAnchor
Old Oct 30, 2009 | 11:04 AM
spoonraker's Avatar
If you want the "draglite" style (second set of pictures) rim that will bolt up to your Camaro without a single bit of modification to your brakes this is what you need.
Brand: Bogart
Style: P1 Series - Billet Lite
This is the man to contact about buying Bogart rims. If you plan on driving this car on the street a lot I would personally recommend not going with the lightest all out drag wheels available, I'm sure SJM can build you a set of slightly heavier, but more sturdy rims in the "draglite" style that bolt on over LS1 brakes without grinding or spacers.
Old Oct 30, 2009 | 04:11 PM
Mr.z/28's Avatar
Brand: Bogart
Yea. man Exactly! thank you. I want something that I can drive on the street. Shes my DD, but I just love that beefy drag look on the 4th gen. I want something that will bolt up right up, no modification or grinding of the caliper. thanks. Ill check that out.
Old Oct 30, 2009 | 04:40 PM
Mr.z/28's Avatar
I checked em out, and they dont look nothing like the ones from the top pic. =/
the weld prostars look like the ones that I want.
Old Nov 1, 2009 | 10:54 AM
bottlefed370's Avatar
The first pic is bogarts, so if you would like to take a look at a pair, you should re-read this thread you made because your answer to what website to find them at has already been posted. You should use search, it would help you alot seeing how you dont know much bout these cars yet.
