15 inch rim
Old Oct 21, 2009 | 10:08 PM
+badss+'s Avatar
Default 15 inch rim
i wanna put some 15x4 and 15x10 pro stars for my 02 camaro ss need to know what bsing for them and is i can run them or is there any fabbing needing to be donei have the chrome 10 spokes on it atm
Old Oct 21, 2009 | 10:26 PM
TooFast3800's Avatar
I'm not sure about it fitting over the brakes. Stock 16" rims give you about 1" of clearance over the calipers in front, maybe a bit less so going with 15" you might not fit them over the calipers. I don't know for sure but I am guessing it will be an issue.
Old Oct 22, 2009 | 06:19 AM
98Z2885's Avatar
Im running a spacer on all 4, and I had to grind the back caliper down a little in the rear.
Old Oct 22, 2009 | 08:44 AM
Camaro396's Avatar
Fronts will need 1.75" and the rears will need 7.50" and the fronts will fit fine with a tiny spacer, and the rears will need grinding on your brakes to clear. If you go with Welds new RT wheels, they will fit all four corners with no grinding, or spacers.
Old Oct 23, 2009 | 12:35 AM
+badss+'s Avatar
thanks ill do a search for the rt wheels see what i can find on them
