Help ID these wheel studs!
Old Nov 20, 2009 | 07:08 PM
happysem's Avatar
Default Help ID these wheel studs!
Ok guys, the rims I got (Y2K's off a 2001 SS) wouldn't fit with my stock short wheel studs, so we put in the guy's "stock" ones and they work fine, but he could only find nine of them.
I go to any autoparts store and tell them I need a factory wheel stud off a 2001 SS and none of them look anything like these;
The heads on the studs say Metric M6177, we tried looking up that part number, but nothing.
Old Nov 20, 2009 | 07:45 PM
toslow5o's Avatar
did u try takin them with u to the parts store? they look like the ones i just put on my car M12-1.50
did they have the blue lock-tite on the heads like stockers do?
Old Nov 20, 2009 | 07:48 PM
toslow5o's Avatar
im pretty sure u can get longer ones from a performance shop or catalog jus make sure u have the correct thread sizing. go in lowes or autozone they have the thread tester junk there
Old Nov 20, 2009 | 08:36 PM
happysem's Avatar
Yeah, I would if I could take them out lol.
They're too long to pull out, I'm not sure how the guy got them in...I wasn't watching.
Old Nov 20, 2009 | 09:16 PM
meatman's Avatar
Those look like the stock ones too me. Stock ones have the part on the end with no thread to help you start the lugs. Any that you will get from auto parts store wont have that. As long as they are 12mm x 1.5 they are what you need.
Old Nov 20, 2009 | 11:37 PM
happysem's Avatar
So you think those are the stock ones from a 98-02?
Guess those are just a bit longer, 1.5"?
Old Nov 21, 2009 | 03:22 PM
9WhiteCamaro9's Avatar
if you have no luck with gettin more or whatever just go to Jegs or Summit and get a set of Mosers wheel studs but tell em what kinda car it is and tell you want the factory style Moser wheels studs and they should have em in stock for the car
Old Nov 21, 2009 | 05:00 PM
99FBODY's Avatar
if thats the rear wheel just pull the sensor out from behind the brake and you can slide the stud through that little hole.
Old Nov 21, 2009 | 11:53 PM
happysem's Avatar
No sensors lol, no traction control or anything.
Well, I finally got it out and brought it up there, got one that works even though it didn't have the flat end on it.
But heres the catch;
Got the new one in fine, tightened it up against the back side by putting on the lug nut, all is good there.
Go to do it on the one I just took out to bring up there and it frickin strips the inside of the hub, theres no more grooves anymore...all flat.
Some guy at Home Depot (went there to rent a grinder to get the stud back out) told me I could buy a slightly bigger one and just shove it in there...
Will that work or do I have to buy a whole new hub or whatever?
Or just be ghetto and drive around with 4 wheel studs?
Old Nov 22, 2009 | 10:12 PM
99FBODY's Avatar
you should have bought two new ones. The grooves on the old one are pressed down and makes it loose in the hole, I have changed out my wheels stud a couple of times and the stud had never been loose.
